head gasket!! wrong size?
Old Sep 15, 2006 | 10:14 AM
94_camm's Avatar
I got a head gasket for my 383 build (.30 over)they head gasket i ordered was felpro 1074.on the bottom of the gasket it says
GASKET BORE-4.125" (is that too big for my .30")??
comp. volume-8.7cc thickness .39..(will this increase compression any)?
Old Sep 15, 2006 | 10:24 AM
96capricemgr's Avatar
Re: head gasket!! wrong size?
Many smallblock gaskets are that large not ideal but not the end of the world either.
Far as increasing compression, over what, you are changing the whole rotating assembly, the gasket needs to be choosen to work with the hardparts.
On an otherwise stock motor it would increase compression since the stock gasket is .049 but whith a new crank and all that means NOTHING.
Old Sep 15, 2006 | 10:27 AM
SStrokerAce's Avatar
No that's the right gasket if you have the block zero decked.
Bret
Old Sep 15, 2006 | 10:57 AM
94_camm's Avatar
wat if it isnt zero decked>?
Old Sep 15, 2006 | 02:20 PM
was it decked at all?
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
