CamaroZ28.Com Message Board
-   -   Which head gasket should i use? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/head-gasket-should-i-use-544547/)
darlandz Sep 23, 2007 08:48 PM
I have a 95 z28 with an lt1 bored .030 over and i have aluminium stock heads that have bigger valves (2. and 1.6 stainless steel) so i was wondering if anyone would like to reccomend a head gasket to me? thanks
mdacton Sep 23, 2007 08:50 PM
on what?
I used fel pro 1074's on my camaro for a while with no problems......have your heads been milled or anything? stock bottom end?
darlandz Sep 23, 2007 08:58 PM
yes the stock heads have been gone through and redone
96capricemgr Sep 23, 2007 09:02 PM
If it was zero decked then the Felpro might be a good choice, otherwise though probably not. It just gets blindly recommended because it is Felpro rather than because it is right.
To make a good recommendation we need to know the deck height and target compression.
Mr. Gasket/Victor Reinz have a .026 gasket which is good for helping raise compression, would be too thin for a zero deck block.
The stock b-body gaskets are .029.
The Felpro is .039
the stock f-body gasket is .049
Cometic has a .027 with a small bore
SCE has been pretending to soon release a .021(same story as MSD opti and Edelbrock intake, Summit ship date gets pushed back every couple weeks)
speed_demon24 Sep 23, 2007 09:54 PM
The Felpro is .039
Do you have any info on the SCE gasket? Like material/bore ect?
truedualws6 Sep 24, 2007 12:12 AM
The Felpro is .039
Great info. I was wondering what the actual dimensions were earlier today
and here it is. I'm going with the B-body gaskets on my head install as
recommended by Ai.
96capricemgr Sep 24, 2007 05:33 PM
Sent Summit an email on the SCE gasket and they are pretending it is available but special order.
They are a 4.060 bore copper reusable gasket.
I am using the Mr. Gasket but hate the packaging issues, the Victor Rienz seem to be the same exact gasket but individually packaged, cost just a little more but worth it to avoid the packaging problems of the Mr. Gasket.
