Has anyone removed the water pump drive shaft and bearing?
Has any done this and left it out? (using an electric water pump) Not needing it in ther anymore, Is there an oil passage in the block to feed the bearing oil?
I have taking mine out and i am having oil pressure problems was wondering if this may have something to do with it or not
Re: Has anyone removed the water pump drive shaft and bearing?
I just took out the internals of the WP, plugged the WP hole, then removed the gear sticking out of the timing cover and left it. No leaks.
-Dustin-
-Dustin-
i left the gear and bearing sticking out of the timing chain cover there so i wouldnt have to worry about filling in the hole...it wont leak and works just as good without removing it
Here is a picture of what I did.
http://www.akgaming.com/~kendall/images/100_0019.jpg
Used a freeze plug for the block.
Its a roller bearing.. It doesn't use oil pressure it uses a oil splash.
I knocked mine out with a hammer then plugged the timing cover with a freeze plug. I did this because I wanted to use a traditional SBC timing set.
