Are Guide Plates Worth It??
Old Jul 9, 2005 | 02:14 PM
Black_Z28's Avatar
I bent a pushrod about 2 weeks ago, and now I'm about to get to work and fix my car. So, I'm about to buy hardend pushrods. Are guideplates worth it? Right now I have a TPIS ZZ409 cam, P&P Stage 3 heads from Precision Porting, 1.6 Comp Cams Pro Mag 1.6 SA rockers. They're only $25 bucks for all 8, so I thought it'd be worth the extra cash. Thanks.
Old Jul 9, 2005 | 02:34 PM
KAT Automotive's Avatar
Re: Are Guide Plates Worth It??
You can't run guide plates and self-aligning rockers, one or the other. Hardened push rods would be fine. Why did you bend the push rod? I strongly advise checking all of your valve train clearances.
Old Jul 9, 2005 | 02:39 PM
30AnvZ28's Avatar
guide plates will help with rockers... prevent a broken piece from getting down into the motor and having a piston.... see what im saying?? If your going to replace your rockers... get some NSA ones, and guideplates... but yeah, hardened pushrods should be just fine.
Old Jul 9, 2005 | 11:42 PM
Black_Z28's Avatar
I bent a pushrod because my #8 intake wasn't set properly. So, the rocker was too loose and the pushrod came loose. Then it bent. Everything else looks fine on the car.
Old Jul 10, 2005 | 12:23 AM
Jameslt1TA's Avatar
The most that i know them to do is provide peice of mind for people. I think it there is also less of a chance to bend a pushrod. I would just stick with what ya got cause its kind of expensive to buy new rrs.
Old Jul 10, 2005 | 10:13 AM
ZMAN Z28's Avatar
What part on minn do you live in?
Z
Old Jul 10, 2005 | 10:51 AM
Black_Z28's Avatar
I live in St. Cloud. How about yourself?
Old Jul 10, 2005 | 01:27 PM
ZMAN Z28's Avatar
Sioux Falls, SD. Close, but not too close for a cruise.
Old Jul 11, 2005 | 01:16 AM
Black_Z28's Avatar
It may be awhile until this is fixed anyways. I just don't feel like working on my car. And my roommate is out for a couple more weeks, so no extra hands. I'll get at it before the snow falls. Then it will go straight to storage.
NewsBot
Sep 30, 2015 04:20 PM
95blkss
Sep 22, 2015 03:18 PM
NewsBot
Sep 14, 2015 09:20 AM
Aaront810
Sep 11, 2015 11:24 AM
blaze309
Sep 8, 2015 05:27 PM
