grr another problem, car jerks wtf??
Ok i just had a problem with the car starting with the recent rain but letting it dry out fixed that. Now we just installed an amp and since then when I take off (like 1 out of 15 times) the car jerks hard like it stalls but the rpms dont go down then it continues on. Its like the fuel cuts out for a second, as if i were to let go of the gas and hit it again. Its only happened since the amp, my bro installed the amp wire in that red + box after sanding down the others wires connecters that were corroded. Thats all we did, is it just bad timing or did he f*** something up with the wires??
Re: grr another problem, car jerks wtf??
Connect your Amp to the power outlet on the back of your altinator... the one that has a red wire connected to it, and tell you brother to never work on your car again.
