Ground Help
Old Oct 10, 2011 | 06:16 PM
ShowOff67's Avatar
Ground Help
The grounds by the vaccum pump. i know the bundle of them hook to the side of the motor bay located by the air intake. but theres one long one with a brown looking wire anyone knows where that goes, cant find anything on the web
Old Oct 10, 2011 | 06:21 PM
RamAir95TA's Avatar
Re: Ground Help
The long ground strap runs from the coil stud to the frame rail under the ABS block.
And the "vacuum pump" is the AIR pump.
Old Oct 10, 2011 | 06:30 PM
ShowOff67's Avatar
Re: Ground Help
thanks!
Old Oct 11, 2011 | 08:10 PM
don's Avatar
don
Re: Ground Help
uninsulated braided shunt goes to the frame if that is the wire that you are talking about
95chwagon
Oct 16, 2015 12:24 PM
autoxr166
Sep 25, 2015 04:21 PM
Greg88
Sep 20, 2015 07:14 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
92_RS_305
Sep 8, 2015 07:47 PM
