ground wire?
Does anybody know what this ground wires is for besides the pcm. Like what sensor is it for?
http://i73.photobucket.com/albums/i2...e/harness3.jpg |
That is to insure that the PCM and the engine have are grounded to each other so that sensors like the coolant temp which ground through the block (water pump) will read acurately. Without it if the pcm has .7 Ohms on its gound and the engine has .1 Ohms on its ground the sensors reading would all be affected by .6 Ohms.
The ground is for:
PCM oil level sensor MAF theft deterrent module transmission range switch (auto) fuel pump relay instrument cluster performance switch (if equipped) traction control (if equipped) ground to DLC |
Originally Posted by shoebox
(Post 4887084)
The ground is for:
Originally Posted by asia517
(Post 5165754)
If this wire isn't getting a good ground would that stop the car from starting?
I was just about to post asking about this same wire. I noticed mine was cut somehow while putting in a new trans and fixing a burned O2 wire on the same harness. Guess I need to ground this thing.
i would imagine they would share the common ground to provide accurate readings and to minimize the chances of any sort of voltage drop which would give false readings and throw off the computer
| All times are GMT -5. The time now is 06:34 AM. |
