got to thinking....
Old Jun 17, 2006 | 12:18 PM
bowtiethunder's Avatar
got to thinking....
about my motor. It's sitting on the stand almost ready to drop in. I recall the machine shop guy telling me to use a external balanced flywheel and 400 balancer. They don't make a 400 balancer for Lt1 do they? So now what am I going to do?
Old Jun 20, 2006 | 08:12 PM
Re: got to thinking....
any suggestions? I'd rather not tear it down and have it rebalanced as its almost ready to drop in. Could I have the LT1 hub and damper matched to a 400 balancer this is the only thing I can think of.
Old Jun 20, 2006 | 08:17 PM
jay_lt4's Avatar
you should have had the crank internally balanced
Old Jun 20, 2006 | 08:22 PM
Kevin Blown 95 TA's Avatar
Doomed! DOOMED!!!
Old Jun 20, 2006 | 08:36 PM
I burn rice too's Avatar
The machine shop should have known to internally balance the engine. I would go down and talk to them. If you have to come to some sort of comprimise. Are you using the stock crank, or is this an old 400 crank and your doing a stroker? If your using the stocker then they should have seen that it was internally balanced.
Old Jun 20, 2006 | 08:48 PM
The stock crank was neutral in front and balanced by the flywheel in back. Do a search on this - I think someone else just went through this very thing and resolved it somehow.
Old Jun 20, 2006 | 08:49 PM
Using 1 piece Scat stock replacement crank. I asked how much to balance rotating assemlby he told me $120+ if it needed metal. I asked if he needed my damper and flexplate he said no so I thought it was going to be internal balanced. I never told him to external balance it and he didn't say he was going to.
Old Jun 21, 2006 | 11:47 AM
jay_lt4's Avatar
i would not trust that machine shop at all, the only proper way to do a balance job is to have the flywheel and balancer so they can balance them at the same time
Old Jun 21, 2006 | 05:14 PM
what would the machine shop need to do to the crank for it to need a 400 balancer, add weight or take weight off? I'm going to have a look at the crank.
red blur
3rd Gen / L98 Engine Tech
Sep 20, 2008 06:11 PM
