Got some wide band results
95 ta a4 with flowmaster muffler,ported tb with screen removed,kn cone.
10.8 to 1 till about 4800 then it dropped to 10.3 to 1 The car ran 14.2 @ 99 with a 2.17 60' with this a/f. I'm installing gears right now and getting a tune from pcmforless, so I hooked up my wide band so i could give him the results for better tuning.I'm thinking the higher rpms with the screen removed on the maf may be making the car get alittle richer. Eric |
Re: Got some wide band results
The tune should help that A/F ratio out. That is way too rich for a N/A car.
Are these normal lt1 results?
Eric |
what elevation are you and how was the weather?
The stock LT1 PCM programming will generally set an 11.7:1 target A/F ratio in power enrichment (PE) mode. That's already too rich. Yours is running way too rich, assuming you used the wide-band correctly. You will make more power in the 12.8-13.2:1 range.
Make sure you give bryan the AFR when you go to get a chip. thats definately odd for a relatively stock car to be that rich. Most are in the late 11's to early 12's
