Got a coolant problem.
Old Aug 6, 2005 | 02:15 AM
Bandit95LT1's Avatar
when im driving around the low coolant light comes on and when the car sit after driveing coolant starts coming out of the over flow i cant find any leeks the is nothing on the dround i have replaced the cap 3 times and tested the cap it works fine friend of mine think it could be a head gasket but i dont think so there is nothing coming out of tail pipe car has plenty of power i have check the water pump and i dontsee any leeks i have looked every were any thought or ideas would be greatly apreciated
Old Aug 7, 2005 | 06:57 AM
slopokrodrigez's Avatar
Re: Got a coolant problem.
2 tests will answer if you have any internal problems. The first to do is pressurize the coolant system and see if it holds.
The second test to do is a leak down. If there are any internal problems in the engine, those tests will find it.
Old Aug 7, 2005 | 07:19 AM
redstriper05's Avatar
hey man I was just having the same problems. I took out the t-stat and left the cap open. If everything is sealed then you shouldn't get any airbubbles or overflow from the rad. Right now I have my engine torn apart because of the same ting and I have blwon head gaskets on both heads. It could be that or a crack in the block or heads. Somewhere the engine sounds like its pulling in air and my bet is it a head gasket. I didn;t have any whitesmoke or preformace problems that i could see but diffenatly no white smoke but i did have some leaks due to the carbon build up on the heads. Its a pain but it will fix your problems and give your engine a chance to get cleaned up pretty good.
Keaton
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
Pwilson59
Sep 3, 2015 08:47 PM
