To go or not to go....
Old Oct 15, 2004 | 07:51 AM
SS RRR's Avatar
I am wondering................
I have replaced my stock fuel pump w/ a Holley 255 and am also going to replace the fuel pressure regulator since it's stock and has over 110K miles on it.
I've heard if you go w/ a higher volume pump then it's possible the diaphram in the stock regulator will fatigue prematurely. I'm not going to be using N20 and will probably set the pressure to ~45psi (going to be using 30# injectors). I am wondering if it would be necessary to go with an adjustable FPR or would the stocker hold up just fine? I have a Holley AFPR that I bought and am mesmerized by it's billet finish yet since I'll only really need to adjust this once... is it necessary for a N/A heads/cam car?
Old Oct 15, 2004 | 08:57 AM
WS Sick's Avatar
Re: To go or not to go....
Most after market AFPRs use the stock diaphram. The aeromotive one and the TPIS one I know are complete units. I'm not sure about the others, but I installed a hypertech on a freinds and it reused the stock diaphram.
Old Oct 15, 2004 | 12:50 PM
SS RRR's Avatar
This Holley unit is complet, however it looks larger in diameter than the stocker....
Old Oct 15, 2004 | 12:59 PM
crash4cyl's Avatar
use the afpr as a precaution.. Plus it allows for adjustability in the future
Old Oct 15, 2004 | 02:37 PM
SS RRR's Avatar
Yeah I'm going to stick with the AFPR for now.
JSkeet
Nov 25, 2014 07:59 AM
mybadd02camaro
Sep 29, 2014 02:22 PM
Verz
May 4, 2010 03:14 PM
blkbrd95
May 27, 2008 08:22 PM
johnsocal
Sep 19, 2006 05:33 PM
