Gm847 and braking
Old Feb 9, 2009 | 04:27 PM
CamaroSS30thAnn's Avatar
Gm847 and braking
Does anyone else have a decrease in breaking after the gm847 installation orany cam similar in size?
If so what can i do to correct this and what is involved in an ls1 brake upgrade?
Thanks for your input.
Old Feb 9, 2009 | 06:16 PM
'94 Bad A Z28's Avatar
Never had a problem like that with mine.
Old Feb 9, 2009 | 07:34 PM
red 95 z28 lt1's Avatar
had that problem with my le2 cam install, tried a vacume canister with no luck. put in an electric break pump from ssbc and havent had any problems since, it not 100% but its alot better then it was off the manifold with the le2
Old Feb 10, 2009 | 10:24 AM
camarobird92's Avatar
My cam is similiar to an 847. I run a vacuum canister and don't seem to have a problem.
Old Feb 10, 2009 | 03:18 PM
marshall93z's Avatar
Only at idle speeds. On the highway they work fine.
Old Feb 10, 2009 | 05:42 PM
Ive always wanted a little more braking out of my LT1 and with the cam i think i need it. Do you think the Ls1 brake upgrade would be sufficient?
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
