gm t56......
just bought a 96 formula... was thinking my speedo was off cause i was doing 1600 rpms at 70mph... i checked 4th with 3.42 at 65 is right at 3k.. so speedo isnt off.. but my question is... is this thing a ZF-6?? according to the gear simulator.. my 6th is .50 :/ maybe the guy switched it out... whats a stock t56 with 3.42s rpm at 70? just trying to figure whats up :) thanks
um, yeah, 6th is .5.:)
GM T-56 SIX SPEED FOR 1994 TO 1997 REPLACEMENT P/N 12558016 This six-speed transmission is used in the 1994 Camaro and Firebird with RPO 1LE performance handling package. This transmission has the same spec's as part number 10236021 above, but with a different gear ratio. For 1994 to 1997 replacement. GM's T56 Transmission Specifications Gear ratios: 2.66:1 first, 1.78:1 second, 1.30:1 third, 1.00:1 fourth, .74:1 fifth, .50:1 sixth, and 3.28:1 reverse. Torque capacity: 450 lb-ft. P/N 10236021 This slick-shifting six speed manual transmission assembly offers the best of two automotive worlds: quick acceleration and economical cruising. For 1993 replacement. T56 Transmission Specifications Gear Ratios: First 2.97:1, Second 2.07:1, Third 1.43:1, Forth 1.00:1, Fifth 0.80:1, Sixth 0.62:1, Reverse 3.28:1 Design Torque Rating: 400 lb-ft Approx. Dry Weight: 125 lbs. |
ok.. ty for the help..... i learn something new everyday :D
| All times are GMT -5. The time now is 10:12 AM. |
