gm t56......
gm t56......
just bought a 96 formula... was thinking my speedo was off cause i was doing 1600 rpms at 70mph... i checked 4th with 3.42 at 65 is right at 3k.. so speedo isnt off.. but my question is... is this thing a ZF-6?? according to the gear simulator.. my 6th is .50 :/ maybe the guy switched it out... whats a stock t56 with 3.42s rpm at 70? just trying to figure whats up
thanks
thanks
um, yeah, 6th is .5.
GM T-56 SIX SPEED FOR 1994 TO 1997 REPLACEMENT
P/N 12558016
This six-speed transmission is used in the 1994 Camaro and Firebird with RPO 1LE performance handling package. This transmission has the same spec's as part number 10236021 above, but with a different gear ratio. For 1994 to 1997 replacement.
GM's T56 Transmission Specifications
Gear ratios:
2.66:1 first, 1.78:1 second, 1.30:1 third, 1.00:1 fourth, .74:1 fifth, .50:1 sixth, and 3.28:1 reverse.
Torque capacity: 450 lb-ft.
P/N 10236021
This slick-shifting six speed manual transmission assembly offers the best of two automotive worlds: quick acceleration and economical cruising. For 1993 replacement.
Gear Ratios:
First 2.97:1, Second 2.07:1, Third 1.43:1, Forth 1.00:1, Fifth 0.80:1, Sixth 0.62:1, Reverse 3.28:1
Design Torque Rating: 400 lb-ft
Approx. Dry Weight: 125 lbs.
P/N 12558016
Gear ratios:
P/N 10236021
Gear Ratios:
