GM Hot cam kit install trouble
Old Apr 9, 2005 | 08:39 PM
Zenger419's Avatar
do the GM rockers need more valve cover clearance?
does the opti make any weird squeeking noises if it is going out ?
I have a chirping squeeking noise coming from the passenger side of the motor. It may be a rocker loose, would this cause the car to miss very badly?
thanks in advance.
Old Apr 10, 2005 | 09:52 AM
TCAL95Z's Avatar
Re: GM Hot cam kit install trouble
If you have the GM LT$ kit you should look around the area of the adj nut.
Mune had to be clearanced right around that nut. I didn't know it until we put in new valve seals.
I've never heard a opti make a noise but I gues it's possible. If your valves are way off on adj or your opti is in wrong your car would run like crap
Old Apr 10, 2005 | 12:23 PM
Zenger419's Avatar
so the valve covers need to have a lil more clearance for that nut then?
Old Apr 10, 2005 | 12:35 PM
sbs's Avatar
sbs
Yes, if the bearing fails. I thought I had a bad water pump bearing but when I got the pump off it was fine - turned out to be the opti bearing.
In your case, if it wasn't making the noise before the kit installation then it's more likely to be from some of the new parts or the installation.
Squeaking opti would not be from the passenger side.
Old Apr 10, 2005 | 12:44 PM
TCAL95Z's Avatar
No the valve covers are fine. The rocker its self has to be clearanced.
If you look around the nut see if it's hitting the rocker. Mine were digging into the rockers
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
Queens94z28
Dec 20, 2014 09:11 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Burn_Out
Aug 18, 2002 08:49 AM
