CamaroZ28.Com Message Board
-   -   fuel injector? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/fuel-injector-813643/)
macsz28 May 23, 2011 04:11 AM
fuel injector?
Does anybody know the part number for 30lb fuel injectors to fit a 1997 Z28?
And whats the best plce to order them? or does anybody here have some for sale? Thanks!!!!
Guest47904 May 23, 2011 05:23 AM
Re: fuel injector?
Why would you need injectors that are only 6#s more than stock?
DAVE00 May 23, 2011 09:05 PM
Re: fuel injector?
+1 - Clarify why you need larger injectors? Also, you do know that you can't just throw them on as you must program the PCM first for the larger size. If you truly do need larger injectors for FI or larger cam/motor then SVO 30's (red top) are a good and popular choice.
henryz28 May 23, 2011 09:31 PM
Re: fuel injector?
What they said why new injectors? If you just need replacement stock injectors I can sell you a set off of my 96 z28 cheap.
macsz28 May 24, 2011 12:40 AM
Re: fuel injector?
I just had my heads ported from Lloyd Elliott and I have a cc503 cam... I was told that I needed the larger injectors... I understand about the PCM... I'm getting a tune as soon as I get the heads put back on
macsz28 May 24, 2011 12:41 AM
Re: fuel injector?
I guess I should of said I have the LE2 heads from Lloyd
DAVE00 May 24, 2011 08:46 AM
Re: fuel injector?
Make sure to add your mods to your signature (set one up) as this is how the rest of us get information on your current setup. Since you have LE2's and the CC503 then SVO 30's would suit you nicely.
macsz28 May 24, 2011 08:35 PM
Re: fuel injector?
I have tried to set up a sig. once before... but since i usually work about 12-14 hours daily I dont have much time... plus I couldnt figure it out the last time i tried.... :think::think::think:
raulz28 May 24, 2011 08:49 PM
Re: fuel injector?
Just click User CP and then click edit signature
