Fuel Block Relay...
I just picked up a new relay box for the fuel relay, the problem is it's a five wire and my current only has four wires going to it.
Anyone know how to get around this or will it not work at all. The relay fits, it just has an extra wire coming out of the block... |
Are you saying you bought a new fuel pump relay and it has an extra terminal? Chances are, you can ignore the extra terminal and go on. Lots of relays are like that. As long as you are not missing one you do need. :)
Nope, it's the relay box. The part the relay connects into.
Originally posted by Bilmind Nope, it's the relay box. The part the relay connects into. |
the problem with ignoring the spare is I am not 100% sure which one is the spare, seeing how the new block wires are all one color.
Originally posted by Bilmind the problem with ignoring the spare is I am not 100% sure which one is the spare, seeing how the new block wires are all one color. What year are we talking about? |
It's a 94.. I appreciate the help. :)
I can take a pic of the new one if that helps. |
Your relay should be marked with some standard pin numbers.
Pink +12v /hot when key is ON/to relay pin 30 Grey- relay power to fuel pump and bridged to prime connector by pcm/to relay pin 87 Drk Grn/White- fuel pump relay control from pcm (should be hot for 2 seconds when key is turned ON and hot when engine is running)/to relay pin 85 Blk/White- ground/to relay pin 86 These should be the 4 wires you need. This pic may or may not help you in some way. |
Re: Fuel Block Relay...
