Freaky Gas Gauge
all of you if you haven't figured this out yet, do yourself a big favor and get a full tank of gas, then never let it drop below a certain point (maybe halfway on the gauge, which is typically 1/4 tank)...you may not know that the fuel pump uses fuel for its coolant, so if you run too low you can and will burn your fuel pump out...do a search and see what kind of a nightmare it is to replace.
the little canister that the fuel pump sits in constantly stays full by pressure whether you have a full tank or a quarter tank. How would a full tank keep the fuel pump "cooler" if theres always the same amount in the catch-can thing??
NUR2S
May 29, 2015 03:52 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
