Foglights not working.
Old May 3, 2003 | 11:30 PM
GEES97TA's Avatar
Unhappy Foglights not working.
Pick up my car today and tonite pulling out of the carshow i noticed my fog's werent on well i looked down and the switch was on and so was the light checked the relay it looked fine.What else could it be? The fog's are new,well from Aug i havent had the car since now so any ideas....
Old May 4, 2003 | 12:14 AM
Lt1t56's Avatar
I have actually had both my fog lamp bulbs burn out at the same time, could be bulbs.
TS 95Z's Avatar
try swapping the relay w/ another one in the fuse box and see if they come on. i've also had bulbs go out after just a few months
Old May 4, 2003 | 01:35 AM
Fastbird93's Avatar
And if it is the bulbs, they're a pita to do.
Old May 4, 2003 | 02:12 AM
camaro6's Avatar
It seems most likely that your bulbs are burnt out. It seems to me that the fog lights like burning out really quick. Ive had my car for 2 years and im on my third set of bulbs. GM should have made these suckers easier to change.
Old May 4, 2003 | 07:55 AM
mobleman's Avatar
An alternative to the factory foglights.
If your sick and tired of replacing foglight bulbs and housings (I'm on my 3rd set of housings and they're toast) You may want to try the 1le grille inserts. You remove the foglight and bracket and just bolt these guys in.
There's a thread in the appearance section discussing this option.
1LE foglight delete
The total cost is somewhere around $10.00 considering a housing costs something like $70, (been a while since I checked) it may be worthwhile for some.
These things look surprisingly nice, matter of fact the featured car in the last issue of Chevy High Performace has these.
I do like the foglights and the way they look, but I've had it with replacing the bulbs and having the glass constantly break.
Just throwing this out there for anyone who's interested in the mod.
Old May 4, 2003 | 09:33 AM
GEES97TA's Avatar
Thanks i hope it isnt the bulb's i just replace them with the hiper white's 8 months ago but they havent been on in 8 months either i just got my car back...ill check them though any other ideas.....
Aaront810
Aug 29, 2020 09:34 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
PROJECT X
Apr 17, 2015 12:13 AM
ishmuff
Nov 25, 2002 01:39 AM
