CamaroZ28.Com Message Board
-   -   floor jack (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/floor-jack-149409/)
doodad Jul 23, 2003 09:31 PM
floor jack
OK found out that my car with the gfx needs a low profile jack (I wanted to put my O2 sims on). Anyone with a source? I am about an inch short on a standard floor jack. TIA
Buhite97SS Jul 23, 2003 09:44 PM
Try rolling your car up on a couple 2x4 pieces of wood to give you the extra clearance to get the floor jack up under your car.
-Mike
93formula Jul 23, 2003 09:46 PM
yeah i drive my car up on 2 by 4s.
z28s Jul 23, 2003 09:47 PM
try driving up on top of a 2x4 then use the jack...thats what i do...i dont have ground fx...just a 2" drop..
stereomandan Jul 23, 2003 09:53 PM
Hey, I just thought of something. Roll your car up on 2X4's and then do it. :D j/k
sc1twntrbo Jul 23, 2003 10:20 PM
well on my ta i droped it abotu 1.5 inches and have slp subframes. the opnly jack i have found that fits no problem besides the stock jack is a cheap $30 jack that sears sells. it even comes wiht a case. but thats about it if i have a flat i hafta use the stock jack to start it then i use a reguilar jack.
revtime Jul 24, 2003 03:01 AM
I use a bottle jack just behind the front tire right where my subframe connector is welded in, I jack it up there and get some room and then put my floorjack under the front.
97; ANN. Z Jul 24, 2003 05:51 AM
invest in a lift! thats what im doing
97FormulaWS-6 Jul 24, 2003 07:51 AM
I use a set of 2x8's for my GF jetta that is lowered 3"... there's NO WAY to get a normal jack under the car without it...
