first start precedures?
ok so my motor and trans are outta my car....i rebuild my lt1 to a 355 with a comp cams 305. i had my engine down to a bare block and had everything hot tanked and jet washed....ok so here is my question..when i put my engine and trans back in what do i have to do before i start it...i know i have to prime it for oil (any how toos?)but what about my radiator and brakes...how do i bleed my radiator without the motor running...and i removed my master cylinder to paint the booster...i also removed the brake part off the lower shock tower where all the lines from the master cylinder connected to... also when i start it do i just bring the r's up to 2-25k and fluxuate them for the "initial" break in?
I am going to pull ignition fuse and crank over engine till I get good oil flow. In theory you should be be ok with the moly lube you use on bearings for initial startup, to not even have to prime. A lot of people prefer to see the oil flow before actually starting engine.
Some will say prime with a drill with intake pulled, where the gear drive is on rear of block.
I would worry about bleeding coolant after you make sure oiling system is where you want it, then work on bleeding brake system. I hope this helps.
I am going to run the dino oil/non synthetic type for a few thousand. I will probably drain oil after a few runs down through neighborhood and hwy.
Check out this link on break in. It is a good way to look at things in my opinion.
http://www.mototuneusa.com/break_in_secrets.htm
The old procedure of setting the engine at a high idle for 20-30 minutes was with flat tappet cams. If you are still using the roller cam, start the thing and drive it gently. No need for break-in as such, except to keep away from high load, high rpm for a while - maybe 200 miles. With a good plateau hone finish on the cylinder walls, the rings will seat quickly, and cam needs no break in at all.
Alex Barnes
Jan 24, 2015 10:21 PM
