fire at the sparkplug and the coil?
Re: fire at the sparkplug and the coil?
Hey there. Do you happen to have more information about the problem? If you have spark at the plugs and coil, thats a good thing
. If you could, can you provide me with a little more information?
Do you have any tools that you could use for testing purposes, such as a digital multi-meter that tests for AC/DC voltage and resistance (ohm)? Do you have a fuel pressure tester? Have you pulled the plugs to see what they look like?
