CamaroZ28.Com Message Board
-   -   Few quick questions (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/few-quick-questions-206187/)
Chevycobb Dec 23, 2003 03:35 PM
Few quick questions
1.) If I wanted to get a set of stock heads for a 94 LT1, what would the part number be??
2.) How long does it typically take to port a set of heads??
I'm looking to get about 330-350rwhp and i'm going to just go with a HOT cam kit, get it tuned, then save up for heads. (It's a stock LT1) I'll probably just get another set of heads to be ported so I can still drive my car until they are done depending on how long it takes. Oh yeah, and I'll be adding headers later on..probably MAC
Ok, one more question...
Just on the HOT cam and a good tune, what range of rwhp could i expect?
Chevycobb Dec 23, 2003 06:37 PM
ttt
FacelessZ Dec 23, 2003 06:44 PM
1) Check out the For Sale thread for stock LT1 heads. You don't specifically need 1994 LT1 heads, but pre-1996 heads will port the best...I'd try '94 and '95 LT1 heads...
eBay typically always has a set for sale as well. Just do a bit of searching...
2) The amount of time it takes to port a pair of heads varies greatly from porter to porter. I had Lloyd Elliott port a set of heads for me and it took about 2-3 weeks because he was a little backed up. You don't want them done real quick because they'll most likely be doing a poor job...
