Failed emissions,180 T-stat help?
Old Nov 4, 2006 | 09:59 PM
BMAN'S SCZ's Avatar
Hey guys I failed emision here in CT. for HC. the limit is 53 and I had a 59. The NOx was 272 out of 614 and the CO was .05 out of .28. So I passed 2 out of 3. I also have my egr deleted. Do you think that if I install my stock thermostat (180) and hook up my egr that it will be good enough. I have a 160 t-stat in there now and the coolant temp stays around 170-175. The wideband stayed at a steady 14-15 A/F the whole time during the test. I run a random tech. hi flow cat. Is there any thing I can add to the gas to help with this also. What about 100 octane? Will that make a difference. Any info will be greatly welcomed. Thanks....John
Old Nov 4, 2006 | 10:10 PM
Sweetred95ta's Avatar
Having it run warmer should help. Also, hooking up the egr should help. Do those and try again.
Old Nov 5, 2006 | 08:22 AM
BMAN'S SCZ's Avatar
I figured it would help. Just wanted to see if there was any tricks as far as fuel additives or anything. Thanks for the reply. Anyone else have any info. Thanks....John
G-BODYT56
Jan 14, 2022 11:14 PM
13qtr
Oct 28, 2016 08:11 PM
Jeff1904
Jun 5, 2016 05:00 PM
damnyankee36
Sep 9, 2015 07:06 PM
tdigger9899
Sep 7, 2015 10:56 AM
