Exhaust Noise
Old Apr 14, 2003 | 12:27 AM
caltommy69's Avatar
Exhaust Noise
Please help me identify this sound. I do not notice it while the car is above 2k RPMS...however...sometimes, when the car is idling, it sounds as if the hatchback area is being subject to large gusts of wind. That is the best I can describe it. I believe it is coming from the exhaust. Any help would be greatly appreciated. I have a 97 z w/56k miles and I had flows installed last month, a week before that I replaced two fuel injectors, and a week before that I installed a K&N filter (the day I purchased the car). This noise started to days ago. Also, sometimes during acceleration I have hear what sounds like very faint "crackles" coming from the exhaust as well. These two sounds started around the same time. Any help would be greatly appreciated. Thanks -=Tommy=-
Old Apr 14, 2003 | 06:02 AM
Thebeast431's Avatar
That sound would be the crappy Flowmaster you put on your car. Flowlessmaster exhausts are a complete joke. They flow just as good if not worse than stock exhaust. And give off that god awful popping noise under acceleration and deaccerlation. I would put the stocker back on and get a cut-out, lots more power, but still sounds horrible. You should do a search here before you purchase anything, that way you can get opinions and dyno numbers to see if it is worth the money.
Travis
Old Apr 14, 2003 | 08:42 AM
EviLBoX's Avatar
I'm not exactly sure what type of sound you're talking about, but maybe your exhaust is rubbing on something in the back of the car. Just crawl under there and check the clearance between the exhaust and the heat shields and such.
Old Apr 14, 2003 | 08:44 AM
Rich_z28's Avatar
Not sure about the sound description. Could you clarify it anymore?
Old Apr 14, 2003 | 11:04 AM
fbird95's Avatar
I'm with The beast431 flowmasters flow isnt good at all. Flowmasters should be called sound master. Engeneered for sound not flow.
kxrawx
May 25, 2015 08:29 PM
May 15, 2015 10:43 AM
Fatdog2
Feb 12, 2015 12:24 PM
karnykamaro
Feb 2, 2015 01:37 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
