exhaust leak from header tube
Old Apr 4, 2004 | 04:09 PM
02transam 513's Avatar
http://community.webshots.com/user/justin513ac
From the tube that comes up off the passenger side bank, whatever was on it blew off while i was driving last night. Could someone tell me can i just block it off, and where i can get something to do that, or what i need to do about it.
Old Apr 4, 2004 | 04:16 PM
stereomandan's Avatar
That's just your AIR tube connector. If you have AIR deleted, then you probably just had a threaded plug in there.
I think a 22mm drain plug works on some AIR threads, depending on year. Don't drive it until you get a plug. Your car will run SUPER rich.
Dan
Old Apr 4, 2004 | 04:19 PM
ok, i'll try and find a 22mm drain plug, does that sound right for a 96 if anybody knows better. I was trying to egg on a race and my car atrting making an awful sound. So needless to say i raced anyway. But she's home till i get it plugged.
Old Apr 4, 2004 | 04:40 PM
also I felt the plug wires and they don't feel burned at all, but the edge of the loom is melted a bit, if it idles ok after i get it plugged is everything a ok.
Old Apr 4, 2004 | 07:22 PM
Yeah, you shoudn't have much of a problem once you get it plugged back up.
You probably just ran rich for a little bit.
Dan
Old Apr 5, 2004 | 02:01 AM
Well Orielly's and autozone both don't have a 22mm drain plug. So for anyone, esp with BBK headers where did you find the plug to fit.
Old Apr 5, 2004 | 08:06 AM
Kataklysm's Avatar
Call BBK and ask the threading. On my MACs it was 7/8ths by 18...emissions threadings are far different then regular threadings so you don't mess with them, I had to have some custom made at a hydraulics shop.
Old Apr 5, 2004 | 09:15 AM
tim95z28's Avatar
You probably need a #10 an union. This is what I used to connect my EGR system on my RK sport headers. This is a link to the connector, but you probably need just a plug the same size.
http://store.summitracing.com/defaul...rt=10+an+union
Tim
Old Apr 5, 2004 | 10:13 AM
OUTLAW_LT1's Avatar
i had this same problem when i got my bbks installed. i went to the local ace hardware and found the right plug for about $4 for 2 plugs. dont know what the fitting is called but anyone at your local ace could probably help
hope this helps
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Jan 5, 2015 07:14 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
