CamaroZ28.Com Message Board
-   -   Engine wire routing help (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/engine-wire-routing-help-889627/)
raroz28 Feb 1, 2023 05:54 PM
Having a hard time remembering how my engine harness was routed on the passenger side. Its the part of the harness that goes to starter (purple wire), knock sensor wire, ground wire and o2 sensor connector.
A picture would be great if anybody can snap one for me.
Injuneer Feb 1, 2023 06:50 PM
Re: Engine wire routing help
Factory service manual has harness routing diagrams. Hard to find the specific items, but worth a look. If you haven’t already downloaded the 1996 (should be same as 97) manual, might be helpful.
https://www.mediafire.com/?40mfgeoe4ctti
raroz28 Feb 1, 2023 07:39 PM
Great link - thanks, Fred.
It looks like this is what I'm looking for, so when i get out tomorrow I'll see how it compares to the car. My long tubes may be throwing me off. I may have had to route them another way and i have just forgotten - its been 1.5 years since i took the car apart.
https://cimg8.ibsrv.net/gimg/www.cam...058379afa2.jpg
Injuneer Feb 1, 2023 09:58 PM
In Shoebox's harness photo (1994/95) that branch has factory insulation on it:
1995 Z28 A4 Engine Harness
Not sure what the minor difference on 96/97 make.
Paul strait Mar 1, 2023 08:39 AM
Re: Engine wire help
I have a 95 LT1 wire harness in a 72 Chevy truck been a night mare I didn't do it I'm just trying to make it run an transmission to shift right an so I got on pcm connector c2 black pin #8 vss output can someone help tell me ware does it go ? The truck has a VDO set of gauge the speedometer is electric so is it go on it to make it work with a ground or any help would be appreciated thanks have a blessed day
Injuneer Mar 1, 2023 09:37 AM
Pin B8 VSS Output connects to the cruise control module, and the instrument cluster. It passes through connector C220
http://shbox.com/1/1995_pcm2.jpg
See harness diagram for location of C220, lower left corner:
The connection at the cluster depends whether the cluster came from a Camaro or a Firebird (you appear to have a non-GM cluster):
http://shbox.com/1/95_z_cluster_pinout.jpg
http://shbox.com/1/95_ta_cluster_pinout.jpg
Essentially it connects to the speedometer, providing a 4,000 pulse per mile signal.
Schematics from Shoebox
