CamaroZ28.Com Message Board
-   -   engine temp sensors (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/engine-temp-sensors-395538/)
ruggerz28 Sep 7, 2005 06:17 PM
engine temp sensors
i pulled the wire off of the temp sensor in the front of the motor cause the fan would no kick on and the car was running really hot, like hovering just under the red, now it runs a lot cooler but the problem is that now its hard to start and the ses light is on. I was wondering if these two are related or if something else is wrong
Dave89IROC Sep 7, 2005 06:52 PM
Re: engine temp sensors
the PCM needs that sensor for correct fuel trim, which is why the SES is on and it starts hard, you need to find out why the fans arn't working correctly,or what else is wrong with the cooling system, with that sensor unplugged, the fans run consantly anytime the key is on
Dave89IROC Sep 7, 2005 06:53 PM
it is possible that the temg gauge is incorrect, temp might be fine...........
Robs97Z28 Sep 7, 2005 06:58 PM
There two sensors, the one on the water pump is for the fans and the one on the drivers side head is for the coolant temp sensor.
shoebox Sep 7, 2005 07:03 PM
The one in the water pump is more important than just the fans as Dave mentioned.
ruggerz28 Sep 7, 2005 10:48 PM
can yall please help me out and give me some troubleshooting tips so that i can figure out what is actually wrong
shoebox Sep 7, 2005 10:50 PM
You can find cooling system testing tips in the "How To" section of my Tech Page.
Robs97Z28 Sep 7, 2005 10:59 PM
Robs' tech pages are awesome!! me has gone to a lot of work to put all the info on there. everything you wanted to know about a F-body is there.
smoknta Sep 8, 2005 02:12 AM
When you say your car is running hot...Define hot. LT1's stock run around 210-220.
