engine swap
My 95 z28 went bad on me :( just bought another engine but its a 93, what parts would need to be swapped out to make things work
Re: engine swap
Hmm good question. Obviously a M.a.f sensor,your o.p.t.I,I believe the ccamshaft may even be different I'm by no means an expert but there are quite a few odds and ends that are different burning believe the short blocks are identical. Maybe someone with more knowledge than me will chime in. I own a 93 z28 but have never swapped anything other than the m.s
d o.p.t.I that is vented |
Re: engine swap
You will probably want to keep your vented opti, so you will need to swap the cam (if the 93 has a stock cam), the cam gear and the front cover. You will need to use your 95 intake/fuel rails. Most other bolted on stuff (which is not much) you just take off your old engine and put on the "new" one.
Re: engine swap
Originally Posted by shoebox
(Post 6889533)
So I should be able to just swap out the cam and cover from the 95? |
Re: engine swap
The stock 93 cam does not have the large hole in the nose to accommodate the vented opti drive, so you have to swap the cam. The newer cam also gives you the longer dowel pin needed. The front cover also has to have the larger hole for the vented opti drive.
| All times are GMT -5. The time now is 10:20 AM. |
