CamaroZ28.Com Message Board
-   -   Engine swap :( (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/engine-swap-547949/)
Tex95Z Oct 13, 2007 11:58 PM
Engine swap :(
Hey all I just bought a 95 Z28 A4 Pole Green.(finally my first 4th gen (even though ive had this screen name for a couple years now) ). I bought it for 1700.00, with 167,000 Miles. So you can guess that it needs a motor, Ive done some searches and have decided to remove the engine from the top of the car rather than the bottom. My question is... is there anything that I should be aware of? I have replaced several engines from 3rd and 2nd gens, but is there anything special about 4th gens that I should look out for? Thanks in advanced for any help.
Will
SevenStars Oct 14, 2007 12:15 AM
Go buy a happy hooker from TPIS... It will make pulling it out of the top a whole lot easier
Tex95Z Oct 14, 2007 12:19 AM
Will do.. Thanks !
JooneJune Oct 14, 2007 02:41 AM
Yessum, get a engine leveler like seven said. A cherry picker would help too lol. Easy-to-do, take the fans/rad off, slip the driveshaft out of the trans,(spray the torque arm bracket with lube (should slip off the torque arm) take the 2 mount bolts out and it comes out in one large hunk of metal. (Drain oil and trans.)
I placed my rear tires about 8 inches of the ground on blocks this way the nose of the vehicle is lowered. The only problem i had was the EWP hit a little, you should be fine tho.
Tex95Z Oct 14, 2007 10:40 AM
Did you remove the accesories, alt. ect?
SnakeOiler Oct 14, 2007 04:33 PM
I took all the accessories off the front of mine before I pulled it out. You'll have to disconnect the shocks on the hood and set it straight up for everything to clear.
dangalla Oct 14, 2007 04:39 PM
you can do it in half the time out the bottom with only a winch
96ZCamaro Oct 14, 2007 05:12 PM
I've done two out the bottom. I find it easy. Plus when your putting it back in if yoru doing it from the bottom it makes things so much easier to just hook up.
