Engine sounds...Knocking, what is it?
Old Sep 24, 2007 | 07:57 AM
vin1382's Avatar
My 93 firehawk has developed a knock. Sounds like a hammer banging on metal esp at idle. My first thought was bearing but i still have good oil pressure. However I havent driven it more then a few miles. I am bringing it in for diagnosing on Thurs. In the meantime, does anyone have any sounds clips of different types of knocking/ticking noises?
I am particularly interested in bearing, lifter, and flexplate sounds.
Thanks!
Old Sep 24, 2007 | 08:23 AM
jsetzer's Avatar
Heres mine when it went
http://videos.camaroz28.com/search/l...a3c40d03e8.htm
Old Sep 24, 2007 | 10:49 AM
Z-RATED94's Avatar
Originally Posted by jsetzer
Ah yes, the death rattle. I hate that noise, even with someone elses car making it.
Old Sep 24, 2007 | 11:06 AM
jsetzer's Avatar
Its just the door to bigger things (and more debt)
Old Sep 24, 2007 | 12:51 PM
vin1382's Avatar
I considered this as well, but decided in the end that once i fix the hawk, im likely going to sell it. I have a new toy already .
Anyone else have anymore clips of various engine noises? I don't have sound here at work but ill listen when i get home. I am hoping to sleep better if i hear something that makes me think its NOT a bearing.
Old Sep 24, 2007 | 01:26 PM
jsetzer's Avatar
My video shows mine making a high pitch sound of the bearing grinding on startup and then as oil flows it turns into just a knock. At first it sounds like a rocker, but after a few seconds it becomes clear its not.
I hope this isn't your sound.
Old Sep 24, 2007 | 03:03 PM
vin1382's Avatar
Mine doenst make any high pitch, but its kinda hard to tell because the car is loud. It just sounds like someone is hammering on metal. Did you have oil pressure at idle and at rev's when your car was knocking?
Old Sep 24, 2007 | 03:13 PM
jsetzer's Avatar
Cold I had normal pressure, fully warm I had lower than normal but still pressure. After driving it @ 60 miles back the the garage and beating the hell out of it I had pretty much none at idle and a few pounds at WOT... which fealt like 3hp.
Pull the dipstick and see if there is glitter on it, mine was covered.
Old Sep 24, 2007 | 05:20 PM
camaro81's Avatar
I've had a strange knocking in my engine since I got it running, I haven't been able to diagnose it though.
Here's an undercar clip I took with my phone, not the best but you can still hear it. When the camera gets towards the rear of the engine (if you can tell) the knock changes to more of a ticking noise, that's the cracked flywheel sound
http://s6.photobucket.com/albums/y21...nderengine.flv
I replaced the cracked flywheel and still have that damn knocking noise, I have no metal in the oil and oil pressure is 30-40psi at idle and 70psi going down the road.
willismoons
Feb 14, 2015 08:42 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
centric
Aug 15, 2002 09:04 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
