Engine Overheating
Old Apr 20, 2003 | 07:38 PM
thefox1's Avatar
Engine Overheating
Just a little follow up on my last post. I was asked to bleed the coolant system with the two bleed screws while the engine was running. Well, that's what I did, but no liquid came out of either.The temp gave was where it usually is under normal running so the thermostat should of been open, as well this is a new thermostat that was put in around november.
Tnx for the info,
J
Old Apr 21, 2003 | 09:24 AM
thefox1's Avatar
Anyone?
Old Apr 21, 2003 | 09:37 AM
teke184's Avatar
hm..if no coolant came out that would mean air came out...right?
so that is a good thing...you opened them when the car was good and warm from driving?
Old Apr 21, 2003 | 10:21 AM
thefox1's Avatar
Well, that's the thing, I left it open quite some time and no liquid came out, I guess it should'nt be any different than bleeding brakes?
Old Apr 21, 2003 | 10:42 AM
MistaClean's Avatar
that would mean your radiator is clogged or there was no fluid in it at all. If clogged take out the radiator take it to a service shop and have them clean out the inside to get out the corrosion....
Old Apr 21, 2003 | 10:45 AM
thefox1's Avatar
well, I checked it and the fluid seemed full, I had my thermostat changed by a garage in november and they said that they change my radiator fluid, so being cloged kind of seems feasable at this point.
Old Apr 21, 2003 | 10:47 AM
MistaClean's Avatar
I work on cars aside from my daily job. How old is the car. If it is more than 5 or so years old pull it out and take it to a radiator shop to have it cleaned
Old Apr 21, 2003 | 11:47 AM
thefox1's Avatar
oh yeah, alot older than 5 years old, it's a 94 that has been very poorly kept up. So that's why I would'nt be surprised if it needed a little tlc
J
Old Apr 21, 2003 | 11:51 AM
MistaClean's Avatar
It cost me about $35.00 for my truck radiator to get cleaned. It is quick and cheap as long as you take it out yourself.
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
willismoons
Feb 14, 2015 08:42 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
