Engine having a hard time starting!
Old Sep 30, 2003 | 09:11 PM
357LT1's Avatar
My car is having a hard time starting! I once thought I had a bad Opti for sure because my car was running real bad along with my starting issue but by scanning it I found out I had an arching issue on the right side of the block. Car runs a LOT better now! I still have the excessive cranking though, along with some high idleing coming to a stop and then it drops where it should be. What else can I check before ordering a new Opti?
One more question! If I had the arching problem when my car was tuned on the dyno this means my car isn't tuned correctlly, right?
Ramiro
Old Sep 30, 2003 | 10:52 PM
357LT1's Avatar
Any input will truly help! Thanks guys!
Ramiro
Old Sep 30, 2003 | 10:57 PM
scoobysnax83's Avatar
yes, I'd say for sure you tune is off. I can't believe they didn't catch that on the dyno
Old Sep 30, 2003 | 11:07 PM
357LT1's Avatar
Well they did see some spike readings and asked me how old my plugs, wires and Opti were. They just weren't thinking about an arching wire I guess!
Should I replace my Opti before heading to the dyno again for a tuning or will my tuning be the same no matter if I have an Opti that may be bad or a good Opti? Thanks!
Ramiro
Queens94z28
Dec 20, 2014 09:11 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
jayblev95
Dec 1, 2014 06:55 AM
thenewkid
Nov 18, 2014 12:57 PM
Chrisdude
Jul 25, 2002 05:54 PM
