CamaroZ28.Com Message Board
-   -   Engine Harness (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/engine-harness-889940/)
weedog Jan 25, 2024 08:14 AM
Engine Harness
Is The 95 Z28/A4 Engine Harness Clickable the Same as the 97 Z28. Thanks
shoebox Jan 25, 2024 08:36 AM
Re: Engine Harness
The harnesses are not the same. There are some additional connections for crank sensor, rear O2s, EVAP monitor...Coil plug is different.
http://shbox.com/1/4th_gen_f-body_ye...onversions.pdf
weedog Jan 25, 2024 08:41 AM
Re: Engine Harness
Thank You Shoebox
