CamaroZ28.Com Message Board
-   -   Engine dies while driving (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/engine-dies-while-driving-886491/)
Aftmost Mar 30, 2018 03:09 PM
So I’m driving just about anywhere and sometimes after a while the engine will sputter and die sometimes it starts right up some times it takes a while to start back up what are things I can check and do to resolve problem engine is a 94 our of a b body
Injuneer Mar 30, 2018 08:02 PM
Re: Engine dies while driving
Check the fuel pressure, with engine under load. Scan it for codes. Have the ICM tested, making sure they get it good and hot. Then there's Scan9495 to run a PCM data log while the car is driven under conditions that produce the stall.
https://www.camaroz28.com/forums/com...95-lt1-874306/
How many miles on the engine? Has the Optispark been replaced? If so, with what brand?
