Emissions Guru's inside please
We have the ASM2525/Curb idle and 40khm 90 second drive test.
I failled the first time without an EGR hooked up,here are the numbers. Allowable in brackets (HC65) Tested 17 (CO%0.36) 0.00 (NO 484) Tested 1127 With the EGR hooked up I still failed Here are the numbers Passed everthing else but NO was now 713 ppm My Oxides of Nitrogen dropped by 414 ppm but I need another 229ppm reduction to pass. BTW the car was at about 200- 220 degrees,should I run the fans? Would putting the stock MAF ends on richen the mixture thereby cooling the combustion chambers reducing the NO count? Any thought or input would be appreciated. |
Anybody?
I found this while t-shooting the exact same prob with my little PU:
NOx Troubleshooting It tends to lead down the path of bad Cat, if EGR and timing are correct. My cat has 140,000 on it and a small, but obvious, leak at the Cat outlet. Tomm I am going to replace the cat, plugs, oil, filters (oil, air, fuel) and retest. I can let you know. Later Sean |
Thanks for the link,I just put a new cat on Oct 17th
My allowable limit for HC is 65ppm on the drive and I tested at 14ppm. My idle test had 200ppm allowable and I had 5ppm |
Ok I think I have it figured out:
1) Change Fuel Filter 2) Change MAF to stock ends 3)Dump the ECM by disconnecting the battery 4) set the fans on low during the test. I will post the results when I get them. |
| All times are GMT -5. The time now is 10:01 AM. |
