Emissions Guru's inside please
We have the ASM2525/Curb idle and 40khm 90 second drive test.
I failled the first time without an EGR hooked up,here are the numbers.
Allowable in brackets (HC65) Tested 17 (CO%0.36) 0.00
(NO 484) Tested 1127
With the EGR hooked up I still failed Here are the numbers
Passed everthing else but NO was now 713 ppm
My Oxides of Nitrogen dropped by 414 ppm but I need another 229ppm reduction to pass.
BTW the car was at about 200- 220 degrees,should I run the fans?
Would putting the stock MAF ends on richen the mixture thereby cooling the combustion chambers reducing the NO count?
Any thought or input would be appreciated.
I found this while t-shooting the exact same prob with my little PU:
NOx Troubleshooting
It tends to lead down the path of bad Cat, if EGR and timing are correct.
My cat has 140,000 on it and a small, but obvious, leak at the Cat outlet. Tomm I am going to replace the cat, plugs, oil, filters (oil, air, fuel) and retest. I can let you know.
Later
Sean
NOx Troubleshooting
Later
Sean
Thanks for the link,I just put a new cat on Oct 17th
My allowable limit for HC is 65ppm on the drive and I tested at 14ppm.
My idle test had 200ppm allowable and I had 5ppm
Ok I think I have it figured out:
1) Change Fuel Filter
2) Change MAF to stock ends
3)Dump the ECM by disconnecting the battery
4) set the fans on low during the test.
I will post the results when I get them.
autoxr166
Sep 25, 2015 04:21 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
