emergency brake cables
Old Mar 23, 2004 | 10:12 AM
KGRESOCK's Avatar
Just completed a rear swap....having a helluva time
hooking up the e brake cables. If I connect one side I
don't have enough slack to connect the other.
Any tricks/tips/advice?
TIA
Kevin
Old Mar 23, 2004 | 04:57 PM
961le's Avatar
stick a screwdriver through the hole on the cable and stick the tip of the screwdriver on the ebrake arm. pry against the ebrake arm and the cable will seat itself.
Old Mar 23, 2004 | 11:01 PM
atljar's Avatar
I pulled the cable out and clamped down on it with vice grips to hold it in the taut position
Boss002
Jan 20, 2016 12:17 PM
whitehooptie
Jul 12, 2015 06:10 PM
Jul 4, 2005 05:00 PM
