? electronics being weird
Old Feb 17, 2004 | 10:52 PM
NewbieWar's Avatar
Question ? electronics being weird
well recently i have seen some pretty weird things... first my speedo started bouncing inconsistantly, but 3 of the needles would do this electricity would go down and rpm's and speed would both go up.
ok next occationally i'll get a weird blinker that blinks "hyper" everyonce in a while but it doesnt do it consitantly like 5 quick blinks 4 reg blinks 7 quick blinks and so on, all the lights work.
yesterday i was driving thro a windy road, and my headlights just went out... i was like WTF!, so i flipped on my foggers, turned the running lights off and flipped it all back on and it all worked again (i dont want this to happen again )
today i had the same bouncy needle thing...
my battery will usually stay at about 12-13 right before the 13 mark on the dash.but today i turned my a/c on and then my power just went down and down (to about 8 or 9volts) ... so i was like fine i'll stay hot and the power slowly recovered, but was doing this bouncy needle thing while it was recovering.
Old Feb 17, 2004 | 10:54 PM
NewbieWar's Avatar
generally my power gauge is fine at idle but as soon as i add something to it (extra gas, a/c, blinker, etc...) it will start to take a dip... somethings more than others, and sometimes more than others...
Spinner's Avatar
Sounds like a short or a bad connection/ground somewhere around the alternator.
Old Feb 17, 2004 | 10:58 PM
NewbieWar's Avatar
well connection wise, my positive terminal on my battery, i think something is missthreaded everyonce in a while the car wont start and if i take that off and put it back on it'll fire right up...
the battery is about 2 months old, so maybe that wire is bad... where can i get a replacement?
Old Feb 17, 2004 | 11:31 PM
If there is no problem with the threads in the battery, you can buy a replacement terminal bolt at the auto parts store. You can even use a regular 3/8 bolt and some washers for a temporary solution.
The terminal in the battery is lead and will strip out if too much torque is applied to the bolt. That is why they only have 5/16 heads on them. However, they must be clean and tight for it to get good contact.
Old Feb 17, 2004 | 11:36 PM
NewbieWar's Avatar
so u think maybe i stripped it? is that covered in the battery's warrenty? (interstate battery 75 months)
i didnt realize it was easy to strip i usually do everything ratchet tight if i can, and on that one it never got tight.
Old Feb 17, 2004 | 11:46 PM
If the battery is stripped, it might be tough to convince someone to warranty it. Dunno.
Old Feb 17, 2004 | 11:47 PM
NewbieWar's Avatar
not trying to cheat any company but if they designed it poorly enough to be damaged there, wouldnt it stop holding a charge very quickly? then need to be replaced for other reasons besides the stripped bolt
Nayr
Mar 3, 2023 08:34 PM
drt
Sep 27, 2015 04:39 PM
ZXXVIII
Sep 1, 2015 10:13 PM
Henson071
Aug 4, 2015 09:32 AM
