CamaroZ28.Com Message Board
-   -   Electrical taping a ground wire... (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/electrical-taping-ground-wire-368857/)
Hawk350 May 20, 2005 04:15 PM
Is this a good Idea or not? I have a wire that seems to be the problem of all my issues. It is long, steel braided. I am thinking about taping it with electrical tape so if it makes contact with a metal surface, it wont affect anything.
captskin May 20, 2005 04:17 PM
Re: Electrical taping a ground wire...
I would think so, just wrap it up in electrical tape real good..
Hawk350 May 20, 2005 04:22 PM
I thought so too, just making sure.... :)
Injuneer May 20, 2005 04:34 PM
If its a ground wire, why would there be a problem if it touched a "metal surface"? All the metal surfaces should already be grounded, and at the same potential as the ground wire.
Hawk350 May 20, 2005 04:42 PM
The ground wire is long, it can potentially try grounding to another point if I run over a bump and it sways....there is much play in the wire...
Dave89IROC May 20, 2005 05:03 PM
and, what is the problem?
Hawk350 May 20, 2005 05:40 PM
my car threw all kinds of codes....lean, est grnd, misfired, and when I adjusted this wired, it was fine. Last night took the car out and ran great wth the wire tucked away. Grounds=problems when not grounded correctly.
Dave89IROC May 20, 2005 05:50 PM
that is not from it touching, it is from corrosion at the ends, I would remove it and clean the ends
Hawk350 May 20, 2005 05:52 PM
which ends, plugs? The has silicone on them....what corrosion are you referring to?
OBE1 95Z28 May 20, 2005 10:20 PM
What is this wire connected to?
