CamaroZ28.Com Message Board
-   -   Electrical problem opti, icm, ecm? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/electrical-problem-opti-icm-ecm-125799/)
SVTbasher May 28, 2003 01:47 AM
Trying to figure out if my opti, icm, or ecm is the reason my car wont start. Turns over just wont start. I'm not getting spark, but getting fuel. Should I pull off the icm first and have it tested? Not really sure where to start that is least invasive before I just randomly start pulling things. Have just narrowed it down to those things. Any suggestions, btw its a 95 Trans am
kmook May 28, 2003 08:40 AM
Lets try LT1 Tech first since this gets discussed alot. Try a search also to save your self some time...
Thanks.
thermwood1 May 28, 2003 11:26 AM
It sounds like it could be the icm. Where did you check for spark at? Plug, plug wire, coil, opti?
If you don't have any spark anywhere, i would try the icm first. I have a 96 , i'm pretty sure the icm's are the same, and i took mine off and took it to Autozone. Well, they didn't have the right connector to test my icm. But, i was able to talk the guy into letting me buy it, and if it didn't work to return it. They cost about $65.
So, you might try this. Good luck.
