Electric H2O pump installation
Old Apr 27, 2005 | 12:38 PM
weinerschizel's Avatar
Question Electric H2O pump installation
I just purchased a CSI electric water pump for my Z28. Now what all is involved in this installation? Will I have to remove the drive shaft from the old h2o pump or will the new one fit w/o dablling with that?
If I must remove it what are the sizes of the plugs I have to use? Is there anything else I should be aware of while installing it? Also does anybody know of any wiring diagrams for the installation? What's a good way to hook it up to the relay box?
Thanks!!!!
Old Apr 27, 2005 | 01:13 PM
tardy007's Avatar
Re: Electric H2O pump installation
This was helpful for me for the Meziere, but I assume it is relatively similar
Here
Old Apr 27, 2005 | 01:32 PM
1SlowFormula's Avatar
I used the writeup above and this one... Good luck, and cover the opti!!!
Old Apr 27, 2005 | 02:25 PM
Red on Red WS6's Avatar
you will need to grind notches in the housing for it to fit. The kit comes with a freeze plug for when punch out the pump shaft. Thats about it.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
BMX Dad
Jan 23, 2015 07:00 PM
Queens94z28
Dec 20, 2014 09:11 PM
