EGR Question
Old Dec 15, 2003 | 09:50 PM
Droff's Avatar
EGR Question
Is the EGR valve controlled by vacuum or by the PCM through a motor/solenoid? If PCM is it used in the first few minutes of run time?
Old Dec 15, 2003 | 09:55 PM
Hotwire's Avatar
the egr is controlled by a pcm activated solenoid that controls the vacuum going to the egr valve. hows that?
the egr is not used until the motor is run for a certain amount of time and you are cruising, map is steady, tps is under a certain percent, and the motor is warm.
Old Dec 15, 2003 | 10:05 PM
Droff's Avatar
Wonderful!
What is warm? Mine sputters after about 1-2 minutes. But it is real strong until then. But it is not up to 180 yet. Would a bad EGR valve that doesn’t throttle the exhaust correctly cause this?
Old Dec 15, 2003 | 10:44 PM
Hotwire's Avatar
well, that is the way it's explained to work in my 97 service manual, just tried to find the parameters for it in lt1edit and all i could find was the map readings.
I don't think the egr kicks in till closed loop, sounds like that's where you're having trouble. you need to get a scanner on your car to see what's happening andn go from there.
Old Dec 15, 2003 | 10:52 PM
HBHRacing's Avatar
acualy the PCM runs an EGR flow test sometimes at startup during closed throttle.
YOu could have a leak in the egr valve pulling air in tho. you can check that with carb cleaner
Noenav
Mar 1, 2019 07:38 AM
edman
Mar 13, 2015 09:39 PM
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
thenewkid
Nov 18, 2014 12:57 PM
