Easy questions?
Easy questions?
1. What did you all have to remove to do the tb bypass there is alot of **** in the way by the 90 elbow?
2. Will it hurt to that off the black mat on my hood? If not how do you that off the shocks the hold the hood up?
3. My friend took spray tire shine and sprayed it under the hood. I thought it was dumb but it looked good. Would that mess anything up if you stayed away from the belts?? THANKS!
Re: Easy questions?
1. The throttle body bypass isnt hard. If u buy one of the $10 kits off ebay they come with instructions.
2. The black mat is there to help absorb heat from the engine bay, unless yours is all tore up and looks terrible I wouldnt take it off unless you have a new one to go in there.
3. My friend says he sprays wd40 on his motor and then lets it burns off and he says it works good so i guess it wouldnt hurt.
Richardan15
May 30, 2015 08:36 AM
ChrisFrez
Dec 15, 2014 03:09 PM
