CamaroZ28.Com Message Board
-   -   easy cam installation (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/easy-cam-installation-88161/)
greg0101 Mar 2, 2003 03:32 PM
does anybody know if it is possible to install a new cam without taking out the engine??
1fast95Z Mar 2, 2003 03:44 PM
This question comes up from time to time and the answer is "no", you do not need to remove the engine. You WILL have to remove the radiator and move the a/c condenser out of the way.
IDOXLR8 Mar 3, 2003 06:49 AM
There is a way to take a cam out with removing the engine. Do a search and you will find your info. :)
EviLBoX Mar 3, 2003 08:38 AM
Here you go:
http://www.streetillusionsracing.com...ll/Cam/cam.htm
white1994z28 Mar 3, 2003 09:51 AM
Heres a step by step on how to do a cam swap:
www.afrashteh.com/guide/install.htm
You don't have to take out the engine.
