dumb ES tranny mount question
Old Sep 17, 2003 | 03:02 PM
Scotts96z28's Avatar
Putting in my new ES tranny mount and noticed the bolt comes with 2 big washers and 1 little washer. Do all of these go on the side of the bolt head or does one of them go on the other side of the crossmember or does it even matter?
Old Sep 17, 2003 | 03:48 PM
sorry for the quick bump, but my car is on jacks and I need to finish quick!
Old Sep 17, 2003 | 04:30 PM
NVetro's Avatar
IS the ES mount like the poly mount? Does it comes with 3 holes on the mount and have 2 studs, 2 bolts, and 2 locking washers? If that is the case, you have to put the stud in as far as possible by putting one nut on, and double nutting the other nut until the stud is bottomed out (use the middle hole) since you only have 1 hole in the center of your trany cross member. after that put the mount on with the 2 bolts to the tranny, then on the put the cross member on, and put the locking washer on, and then the nut. That help?
Old Sep 17, 2003 | 06:04 PM
The mount came with 2 bolts, 4 large washers, 2 smaller washers, and does have the 3 holes. I'm just wondering how many washers to use, where, and if it even really matters.
Old Sep 18, 2003 | 10:57 AM
NVetro's Avatar
Well it seems all those extra washers are spacers of some sort. What i would do is put the stud into the middle hole and double nut it down. put it on and then put the nut and 1 locking washer on, see how it is, you dont want the tranny at to much of an angle. Sound good guys?
Old Sep 18, 2003 | 11:24 AM
madwolf's Avatar
I only used one bolt and washer on both my 95 and my 93.
We only have one hole in the crossmember, but remember, that mount was made for a wide range of vehicles that may require the extra bolts/washers supplied with the kit.
Old Sep 18, 2003 | 11:42 AM
Thanks for your replies!
mattszm6
Dec 14, 2014 07:09 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
rpm4lalo
Aug 3, 2002 02:35 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
