CamaroZ28.Com Message Board
-   -   Dtc 16 (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/dtc-16-a-502675/)
lt1street Feb 15, 2007 10:01 PM
Dtc 16
Hey guys what does this code mean. i know its dist. ingition system ( low resistance) thats what the book say at least. i have a new MSD dist. about 1000 miles on it ,park the car for about two weeks went to starrt it now no spark. ???? thaxns guys
shoebox Feb 15, 2007 10:36 PM
Not low resistance, but low resolution. It means the computer is not seeing the low resolution pulses from the optispark. Could be a problem with your connection at the side of the intake manifold. Hopefully, not your new MSD. Check fuses, just for the heck of it, too.
Injuneer Feb 15, 2007 11:15 PM
If DTC 16 is "active", the PCM shuts down the fuel system - pump and injectors = no start. Clear the code by pulling the "PCM BAT" fuse for 30 seconds, and see if it comes back.
