Driveshaft help!!!!!
Old Apr 9, 2003 | 05:38 PM
swamper's Avatar
i have a 1996 Z28, with some mods, but the main point is my aluminum driveshaft. today i dropped my clutch at around 3000rpm's, and it just shredded the yolk on my driveshaft!!! my u-joint is gone, and the driveshaft is separated from the rear-end, but is still hanging from the tranny. my gears still work ok, and everything shift well, but my car will not drive. Has anyone had to replace their driveshaft before, even with a stock one, and around how much did it cost?! thanks
Old Apr 9, 2003 | 05:53 PM
teke184's Avatar
you can pick up used steel shafts from the lt1's for around $50-75.
or you could get a used aluminum ls1 shaft for about $125-150
or an aluminum 1le shaft for around $200
or pay mucho $$ for an aftermarket alum. shaft or carbon fiber if you really want to blow some dough
Old Apr 10, 2003 | 03:28 AM
1FASASZ's Avatar
from 82-2002 are all the same i broke my driveline at 150 mph and got one off a 85 firebird v6 for like 20 bucks
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
realistyc
Jul 28, 2015 07:32 PM
