drivers side header bottom??or top??
Old Jan 31, 2004 | 07:04 PM
SiDeWaYZz28's Avatar
hey everybody im bout to put in my headers first im doing the drivers side...does it go in through the top or bottom????????thanks.......by the way they are long tubes
Old Jan 31, 2004 | 07:13 PM
Kain's Avatar
Bottom, both of them. I took out the steering knuckle so I didn't have to deal with the slip tube, but if you find that to be too much of a hassle, you can just slip the tube out, and fit them up.
Old Jan 31, 2004 | 07:18 PM
thanks kain...how high did you have your car up??
Old Jan 31, 2004 | 07:20 PM
Kain's Avatar
Really, really, really far. I had a small jack and jack stands; I had to run to Autozone and get the big 3 ton floor jack and the biggest jackstands. Next I had to go to Home Depot, get solid cinder blocks to put the jack on to get the car up high enough.
You've almost got to slide them in vertically, then tilt them into place.
Old Jan 31, 2004 | 07:26 PM
1FASASZ's Avatar
Smile
i put my drivers side in though the top
Old Feb 1, 2004 | 12:11 AM
do they have to be solid blocks
Old Feb 1, 2004 | 12:14 AM
Kain's Avatar
Yeah, I had 6" tall thin cinder blocks with tiny slots in them, and one crumbled when we were jacking up the car.
The other alternative is unbolting the motor mount on one side and jack up the engine.
You can always experiment to see what works best.
Old Feb 1, 2004 | 12:26 AM
kain did uhave to take off your oil filter??
Old Feb 1, 2004 | 01:12 AM
Kain's Avatar
Nope.
Old Feb 1, 2004 | 04:47 AM
carlos64030's Avatar
I put my Hookers in through the top...both sides.
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
Roshambo
Sep 4, 2002 11:25 AM
