CamaroZ28.Com Message Board
-   -   Dont know what else to do... (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/dont-know-what-else-do-268561/)
CodysRedZ Jun 3, 2004 07:30 PM
Alright im out of options...i lowered my car with bmrs....now ever since then the right front squeaks immensely...the left does to but not near as loud....it doesnt do it at first but after a couple of minutes of driving it squeaks over ever bump and even when i brake....i know everything is tight, and we did everything right, so what could it be? Someone told me to check the sway bar and put grease on the bushing did that..didnt work..im out of options and its so embarrassing to drive bc it sounds like a piece! PLEASE HELP!!!
tanmanski Jun 3, 2004 07:52 PM
did you do just the springs, or other stuff too, i.e struts, strut mounts, ctrl arms, bushing kits? Are you sure the spring "tail" is properly seated in the contour of the rubber cushion?
slopokrodrigez Jun 4, 2004 12:26 PM
Sounds like you put Eurothane bushings in. Try this, spray one bushing at a time with something like WD and take it for a short ride. If that's not it, stop and spray another one. Keep doing that until you find it. Don't forget the the upper A arm, the lower arm and even do the back if need be
